aahighfly (guest)
Guest
Posts: n/a
I have a new twist to this ignition switch problem. My horn will not honk with the key turned from the off position. It will work again as soon as the key is turned to off AND the key is removed. The electrical portion of the ignition switch was disconnected while troubleshooting so I have ruled out the switch as the problem. There seems to be a circuit made when the key is removed since it affects the chime at the same time. There is a wiring harness leading to the steering wheel locking mechanism but I was unsuccessful at removing the whole ignition/locking mechanism because the panel on the left of the switch containing the headlight switch and air louver would not come off without forcing it and I didn't want to damage it. In the photo of the replacement locking mechanism I see no wiring so I don't know what to think about where the switch involved is installed.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Ignition Switch Replacement - 986 / 987
Old 11-15-2011, 12:53 AM
