max (guest)
Guest
Posts: n/a
after swapping engine, the clutch is not up, do i have to refill hadrualic fluid and where?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Engine Conversion Project - 986 Boxster (1997-04) - 987 Boxster (2005-08)
Old 12-18-2011, 01:21 PM
Author of "101 Projects"
Wayne 962's Avatar
Possibly. The brakes and clutch use the same fluid, so if your brake fluid reservoir is full, then that is not the problem. You might need to bleed the whole clutch hydraulic system, full instructions here: http://www.pelicanparts.com/techarticles/Boxster_Tech/45-TRANS-Clutch_Hydraulics/45-TRANS-Clutch_Hydraulics.htm
- Wayne
