Rog (guest)
Guest
Posts: n/a
How do I remove the trunk liner so I can check for coolant tank leaks under the liner. I have a 2006 Boxster
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Coolant Tank Replacement - 986 / 987
Old 12-27-2011, 11:57 AM
Author of "101 Projects"
Wayne 962's Avatar
The trunk liner is held on simply with a set of plastic screws & snaps. Take my word for it - you will break a bunch removing the liner, so just order some new ones (from Pelican) to have as spares.
- Wayne
There are some screws near the center at the latch cover. Then a few of the fasteners are sort of threaded expanding plastic molly bolts and others just pry out (no slot on the cap). Buy a trim remover tool and you might get a few out without breaking them. The tool is kind of a small prybar with a forked end to fit around the fastener.
Watch out around the trunk light bulb. That thing gets hot! Ask me how I know.
Old 12-28-2011, 07:14 AM
John Bosmans
John99Boxster's Avatar
Wayne...what is the part no.(s) on the retaining snaps?
1999 Boxster
Midnight Blue Metallic/Savannah Beige | Tiptronic | Custom Rear Spoiler | 17" Turbo twist | Red Brembo Calipers | Glass Rear Window
Old 12-28-2011, 08:45 AM
This is all fine and dandy for 986's, but the coolant bottle is moved to the engine compartment on 06's guys. You shouldn't need to remove anything from the trunk as it's just an access (fill) port.
Old 12-29-2011, 10:06 AM
