Another small update as I await parts delivery to finish this up. I found a person that builds a knock meter that could be tuned to a bearing with the beginnings of pitting or flaking etc.
He sells these on Ebay for 50$ w/free shipping. This is cheaper than what I am able to put together. I will be looking to change the box it is in, and warning light to fit the appearance of the dash. So far this will make it $118.
---------------------------------------------------------------- 98 Boxster 87 560sl 04 S2000 |
závodník 'X'
Excellent. Could also be ideal for 2 stroke snowmobiles, especially if you get a bad tank of fuel.
A couple of quick questions: How is your bearing system different from the Insaro system introduced in Europe about two years ago? Exactly where would the knock sensor be mounted so that it is listening to the IMS bearing and not confused by other normal mechanicals’ of the engine?
Accrochez-vous bien de vos ręves..........." |
I haven't seen any signs of the Insaro being installed on this side of the pond. No idea of the availability of instruction materials, qualified installers, tools, price etc. Nor numbers installed.
The ultimate IMS UPGRADE - 6speedonline.com Forums |
JFP,
The Insaro system is a very well eng. piece and I am sure without a doubt it will work as expected. I believe he says when it fails, it will last 5 mins. so you can pull over to a safe place. Exactly what mine will do, but with over the counter parts that anyone can buy on the fly cheap. The bearings also fit on the original parts. As for the sensor, when I was messing around with it, I stumbled onto how to make it a directional mic instead of a wide sweep listening device. That will be disclosed later and is an easy mod to the sensor. The sensor will be located in the IMShaft pointing toward the bearing.
This should be a big enough warning, eh?
I think it will need to be resessed more..... ![]()
Inquisitive user
Feelyx, Appearance wise. Yes recessed more. If you could get a blank for that hole, drill out the center to match the outside white lines of it and recess it behind that. That would be kewl. Keep on trucking. Or Boxstering?
Randy
Perpetual change. It will happen!!! |
I'm thinking spray tinting the inside of the red cap so it won't be noticeable. Until it goes off.....
Inquisitive user
Audible warning too......
závodník 'X'
Agree on the audible warning and have it overcome a radio too. The beacon looks good to me and hopefully one could see it with the sun shining.
Just in case the flashing light and the audible alarm siren are not enough perhaps a stiff squirt of water in the face would do the trick! Something similar to the flower on a clown's lapel. You could tap into the windshield washer tank without too much modification.
Inquisitive user
![]() Randy
Add a claw that springs out and grabs you by the nuts, that'll get your attention!. LOL!!!
2001 Boxter S
so... if that's the way we are going... Then" The IMS monkey" will be the best solution.
(look for "trunk monkey trilogy" on you tube. I'm posting from my iPad so can't give you a link)
found one........
![]() crow bars and donuts not included....
