issue with a 2006 boxster s
Bought a super clean 2006 boxster s from a copart auction. I have an issue w the motor struggling to star.. it backfires and pops and just wont idle or rev past 1200 rpms.
Wondering if anyone has any suggestions.. I purchased the durametric software and I appear to have no engine codes. Before I start spending money randomly, I was hoping that the boxster community could provide some ideas or guidance. I will try the following items. Maf Crank and camshaft sensors Fuel pump Spark plugs and or coils Vacuum lines And oil separator Wondering if anyone has any other suggestions Thanks CB |
Vacuum leak?
anybody? was hoping that someone had run into something like this and had some insights of where to start
Check fuel pressure. Most of the other problems would cause codes but most of the time low fuel pressure won’t.
Pull a vacuum line off and spray carb cleaner in it while starting and see if it makes a difference. How many miles on it? Try unplugging the maf while it’s running and see if it changes. Keep us posted. Tony Last edited by Bigtoe32067; 07-04-2020 at 10:26 PM.. |
Unplugged the maf, I'm starting to suspect a fuel pump or filter. The car has 72k miles on it and I have all the service records.
It is super clean. I was just wondering if anyone had a similar experience and could provide some insight on troubleshooting |
If it's running that bad, you have to have an engine code. Codes are the starting point so you're not guessing and throwing lots of $$$ at those guesses.
PCA National HPDE Instructor 2008 Boxster S Limited Edition #005 2008 Cayman S Sport - Signal Green 1989 928 S4 5spd |
no codes. used Durametric and no check engine light and no code. pretty sure its a fuel pump. taking a fuel pressure reading later tonight.
Damn, got 50 psi at each rail... pulling the plugs tomorrow and checking the fuel pressure regulator and the wires/coils tomorrow
The car runs like hell and cant get above 400 rpms without stumbling and sputtering. Kicked out a cloud of gray smoke today
It'll be legen-waitforit
Check your gas cap
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Proud 944 Owner
Sucks it won’t idle and no codes. So no live running data. Any freeze frame data? On a possible event failure captured? My Autel can usually get history data before clearing faults and freeze frame at time of fault. Being from an auction the car could have been tampered with. Pulled fuses or replays, things unplugged. Ground disconnected. Start at the basics, air, fuel, spark, compression. If it has those 4 things mechanically speaker you’re good.
