-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Swapping out ignition, immobilizer/CLU, DME (http://forums.pelicanparts.com/boxster-cayman-forum/675421-swapping-out-ignition-immobilizer-clu-dme.html)
healthservices 05-01-2012 10:53 PM
It looks like I found a bad box under the driver's seat due to a short and liquid contamination, Immobilizer/Central Locking Unit Whatever you call it. Owner is suggesting a used matched, ignition, key, Immobilizer/Central Locking Unit, and DME from same year car. Will this work? SmileWavy
Wayne 962 05-01-2012 11:38 PM
The box under the driver's seat is the alarm unit. What you have suggested will work, however, I believe that all you need to do is replace the alarm unit under the seat (unless the short has fried more things). On the early Boxsters (you don't mention which year), the key, immobilizer, and the DME must be the matched set.
-Wayne
healthservices 05-02-2012 06:48 AM
This car is a 99. To replace the alarm unit under the seat by itself would require programming and a code I can only get at the dealer correct, or can I just install the alarm unit without coding?
What other options do I have? Owner can get a pre-owned matched Key, alarm unit, and DME out of a same year car for about $700
healthservices 05-02-2012 10:06 PM
Well the owner started getting scared of what other issues the car might have if the car started. So we ended up selling it to a Porsche tech a couple hours ago. I'm sure he will have no issues getting it going.
Thanks anyways
ScottT80 05-15-2016 07:28 PM
So I'm in a similar boat with a '99 I just bought. Anyone have any input on this? Thanks!!
ScottT80 05-19-2016 06:04 PM
Anyone?
JFP in PA 05-20-2016 05:47 AM
Originally Posted by ScottT80 (Post 9128072)
Anyone?
See my post in your other thread; this will not be a cheap fix.
S ECU Repair 05-26-2016 06:13 AM
healthservices,
Replacing the Immobilizer from your Boxster will require programming.
Since you mentioned about putting a matching DME Set from another car let me advise you against that.
From reading your notes it sounds like you want to put as little money into the car as possible.
We made about video about why this is a bad idea: https://youtu.be/QCOunBZL_Yk
VIN # will be different in DME and therefore that can open a can of worms.
It's much cleaner and simpler to solve the issue with the OEM set that you currently have.
