Certified Porsche addict
The Glademister's Avatar
Charging system problem light on
My girl friend's '02 Boxster with Tipronic had the charging system problem light come on yesterday. Ruled out the drive belt with PS and engine cooling working fine. I metered the battery with the car off and on and didn't see significant voltage loss. I'll get my Durametric on Monday so I'll get the code. But until then, what should I suspect as potential problems?
Tennessee Region SCCA & PCA
Current projects - '87 944 Turbo, '87 924S, '82 931, '10 Boxster (the girlfriend)
Past projects - '83 944, '02 Boxster (x2), '99 Boxster, '14 Cayman,'72 Opel GT, '75 280Z, '90 300ZX, '87 944S, '87 944 Turbo, '88 924S (x2), '07 Cayman S, '73 914, '88 MR2 AW11
Old 05-17-2012, 08:10 AM
Paul V
paulv's Avatar
Originally Posted by The Glademister View Post
......... I metered the battery with the car off and on and didn't see significant voltage loss. ......
Key off: battery should be approx 12.6 volts
Engine running: battery should be at least ~13.6 volts at idle (increasing with rpm)
Regards,
paul...
07 Boxster S, 03 MB E320 (wife's car), 10 Subie Forester X
Old 05-17-2012, 09:22 AM
Fixed last night. Dead cell in OEM battery. I'll zap the code away Monday.
Old 05-18-2012, 08:52 AM
Author of "101 Projects"
Wayne 962's Avatar
Batteries typically last about five years (sometimes much longer, sometimes a bit less). If a battery is older than that, I would suspect it as the primary cause of issues like these...
-Wayne
Old 05-18-2012, 10:31 AM
Stuffing in the windings
Of course nothing could be as easy as replacing the battery...
GF called Friday evening and the '02 Boxster is dead. Hauled ass out with the trailer and got the car loaded up (after several jumps to get the brand new battery charged again). So it's looking like the alternator is suspect. I did meter voltage right after installing the battery and was only seeing 12.3V engine off and less than 13V with the engine running. So yesterday I read the procedure and pulled the alternator. Looks like mice have been building a nest behind the alternator and stuffing it with crap. Not at my house because we bait but probably from a PO. The good news is I found a local shop that will rebuild the alternator for $175
Alternator stuffed with trash.
More garbage on top of block behind the alternator.
Old 05-21-2012, 11:04 AM
