High beam issues HELP
Ok my 2001 boxster has an issue I have head lights that turn on low beams are good I can flash my high beams but they will not turn on in the on position? Is there a relay or is the switch bad? Please help
Additional info
I am mistaken I hasve very dimm lights I can flash high beams but not working correctly help
Just wanted to say thank you this forum is great always saves me money and helpful. Thanks I used your pictures to replace a headlight switch and a window regulator saved a ton
