-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Engine Rebuild Manual or Specs? (http://forums.pelicanparts.com/boxster-cayman-forum/689197-engine-rebuild-manual-specs.html)
harrisracing 07-16-2012 12:15 PM
I am looking for resources for the specs / rebuild process for the 2003 (3-chain, single row bearing) 2.7L Boxster engine that I inherited from my mother-in-law. Torque specs and rod bearing / main bearing specs would be greatly appreciated. Also cam timing specs for the reset of the cam timing.
I will be sending my IMS shaft out to be checked / pinned and will be going with an aftermarket bearing upon reinstall. SO far, the rod bearings look pretty good and I am currently debating even changing them as this engine only has 25k miles of life on it now.
Thank You,
Patrick Harris
Wayne 962 07-17-2012 11:15 AM
There's not much out there info-wise just yet - the best bet is the factory manuals (which don't say a whole lot). I have found that the 996 manuals are much better than the Boxster ones.
As for the cam timing, it's not the same as on the 911 - you just set the timing tools in place and line up the chains and you're good to go.
-Wayne
harryrcb 07-17-2012 08:59 PM
Both Mitchell and Alldata have online access for your car purchase for a year I think it is around $20 . It should have everything you are looking for, I like Alldata better but that's just a personal decision.
harrisracing 07-20-2012 05:45 PM
Thank you
Thanks for the replies. Much appreciated.
Patrick
