Guest
Posts: n/a
Also too. With the 98 boxster
It's been hot here the last couple of weeks. Running the car with the ac. The thermostat really starts to rise close to the 120. Is it in need of a simple coolant flush or radiator flush. I know it's hard guess without looking at the car. It just seem every time I take it in. The dealership takes me for more$. Thanks for all your help. This site is great __________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Convertible Top Repair - 986 / 987 |
Are the radiator cooling fans running at high speed? A cooling system flush is a good starting point. You want to confirm cooling fan and thermostat operation too.
- Nick |
Author of "101 Projects"
Yes, it's common for a relay problem to cause the fans to stop working. A failure of one of the sensors will do this as well. The two fans should run on high with the A/C on regardless of the outside temperature. I would check to make sure this is happening properly.
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
