Covekev (guest)
Guest
Posts: n/a
Water condensation is Leaking into the passenger floor panel 2002 996c2. I assumed it is the ac drain but would like to know how to repair.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Air Conditioning Recharge - 986 / 987
Old 07-27-2012, 10:35 AM
Nick at Pelican Parts's Avatar
You can access the HVAC housing drain from inside the vehicle. I would bet just clearing it of debris should fix your problem. Remove the glove box or lower instrument panel trim. You'll see the drain attached by plastic tie strap. You can remove it an clear it. Be sure to route it properly when re-installing.
- Nick
