Sam (guest)
Guest
Posts: n/a
Anyone know what is the bolt torque spec for the two bolts that attach the triangular bracket to the side of the transmission housing case?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing Boxster Transmission Mounts - 986 / 987
Old 07-27-2012, 09:12 AM
Nick at Pelican Parts's Avatar
Not knowing the exact year of your car I had to shoot for a mid-production year vehicle. Here are the specs for the mounts along with bolt size.
Hydraulic mount on support side part M8 25 Nm
Hydraulic Mounts To Carrier Side Part M8 23 Nm
Transmission support to transmission M10 65 Nm
If you send me year and transmission type I can be more sure of the specs.
- Nick
