Artic99 (guest)
Guest
Posts: n/a
Attached is a picture of the main transmission shaft bearing behind the throw-out bearing support tube.
Wondering if this looks like it's supposed to?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Clutch Replacement - 986 / 987
Old 07-24-2012, 03:13 PM
Nick at Pelican Parts's Avatar
The bearing looks like it has failed and requires replacement.
- Nick
harryrcb's Avatar
Yup - bearing is toast
Crazy Austrian
http://www.ws-ab.com
Old 07-24-2012, 07:39 PM
Bearing removal?
Can anyone advise if this bearing is pressed in, or can it be removed with a hammer-slide type bearing puller? There was a snap-ring that I've already removed.
I have a replacement bearing.
Old 07-31-2012, 11:30 AM
Author of "101 Projects"
Wayne 962's Avatar
Should be a press-fit - you might have to chip away at the outer side of the bearing in order to get it out. I personally have not changed this bearing previously, so I'm not really 100% sure.
-Wayne
Old 07-31-2012, 01:36 PM
