gearbox reverse switch
Hi,
New to this forum so please excuse me if anything similar has been covered already. Anyway my dad pointed out the other day my reverse lights werent working when i visited, so when i got home checked bulbs, fuse etc and norrowed it down to the reverse switch on gearbox.
So i promptly removed the switch (would have been a damn sight easier had i known it was this before putting the exhaust back on an hour earlier after having hayward and scott bypass mod done). Never mind the switch was deffinately at fault siezed solid infact.
Here is my query though as i removed the switch air was released from the gearbox quite alot infact as though it had built up pressure. Ive had this happen on 4x4 axles before when the breather is blocked. Is there a breather on the gearbox or is this normal Just so you know the car is dry as a bone underneath no oil leaks at all and its a 986 2001 boxster s sorry if this is a daft question.
Old 01-20-2013, 03:56 AM
i believe there is a breather, sounds like it needs cleaning
Old 01-20-2013, 04:32 AM
Tags
gearbox , reverse , switch
