sailman (guest)
Guest
Posts: n/a
2002 Boxster S drove 50 miles no issue. Stopped to buy a bulb and 5 mins later Red overheat on temp came on, white smoke and coolant dump. I am assuming a thermostat ordered but when I tried pressure testing coolant seems to be coming out just above the right diff can't see exact location ie under reservoir. Should I be looking for another problem?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Coolant Replacement / Boxster Coolant Flush - 986 / 987
Old 05-27-2013, 12:15 PM
Nick at Pelican Parts's Avatar
It could be a coolant hose leak or the engine oil heat exchanger. Try using a mirror when you pressure test the system to pinpoint the source.
- Nick
sailman (guest)
Guest
Posts: n/a
Old 05-27-2013, 12:16 PM
- Nick
Master Tinkerer
illusionist's Avatar
If the leak is from a plastic valve above the differential towards the right rear, it could be the triptronic cooler valve (if your car had triptronic trans)
Old 05-27-2013, 05:14 PM
