Nick (guest)
Guest
Posts: n/a
2000 boxster...while driving the car starting losing power. When I stepped on the gas it bogged...and rpms and power kept dropping. Eventually the car died. Then I was able to start it..but it ran rough and quit. Now the engine cranks but won't start. I tried the unplug the mass air sensor trick...but it still just cranks but won't start. I jumped the fuel pump relay and turned the key...heard nothing. Should I hear the fuel pump with the front hood up and the battery still installed?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Fuel Pump Replacement - 986 / 987
Old 06-11-2013, 04:54 AM
Nick at Pelican Parts's Avatar
If you have the fuel pump activated, you should hear it running. Try removing the fuel filler cap and listening via the filler neck.
- Nick
jon (guest)
Guest
Posts: n/a
Hi,
On a Boxster 987, is there an 'easy' way to access the relays? They are mounted connections down / relays up above the fuse box in the footwell and access appears to be appalling - is there a trick to unclipping the relay board to get better access?
Thanks!
Old 06-11-2013, 05:00 AM
There are retaining lugs at the sides of the relay panel. Once you detach these lugs, the panel can be pulled down for better access.
- Nick
