louie the 13th (guest)
Guest
Posts: n/a
How do you bleed the slave cylinder?
Please explain in detail.
I just ordered the book also thanks.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Boxster Clutch Hydraulics Overhaul (Boxster Master Cylinder & Boxster Slave Cylinder Replacement) - 986 / 987
Old 06-11-2013, 05:17 AM
Nick at Pelican Parts's Avatar
The slave cylinder repair info is here: http://www.pelicanparts.com/techarticles/Boxster_Tech/45-TRANS-Clutch_Hydraulics/45-TRANS-Clutch_Hydraulics.htm
The tech article states to use the bleeding procedure located here: http://www.pelicanparts.com/techarticles/Boxster_Tech/48-BRAKES-Bleeding_Brakes/48-BRAKES-Bleeding_Brakes.htm
- Nick
