Author of "101 Projects"
Wayne 962's Avatar
I just realized that my captions are missing from the tech article:
A- Fuel rail
B- Intake rubber sleeve with vacuum port installed on the right side of throttle body
C- Fuel pressure regulator on fuel rail
D- Air injection pump valve
E- Electronic vacuum solenoid valve for air injection pump valve
F- Vacuum reservoir
G- Four-way vacuum tee
H- Vacuum check valve black side points toward the manifold
I- Three-way vacuum tee one side is plugged
J- Electronic vacuum solenoid valve for resonance flap valve
K- Resonance flap valve
L- Intake rubber sleeve with vacuum port installed on left side of throttle body
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-14-2013, 03:45 AM
Nick at Pelican Parts's Avatar
Okay
- Nick
