kobsvt (guest)
Guest
Posts: n/a
I just got a 1997 Boxster 47,588 miles is it time for a replacement IMS bearing,small oil leak frount side of oil pan.it makes noise at start up only once then goes away. ??????????? thanks for the time.
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-14-2013, 04:31 PM
Nick at Pelican Parts's Avatar
Your probably losing oil pressure for the timing chain and the noise goes away once you've started the engine and built oil pressure in the tensionser. Just a guess through.
- Nick
