Brian (guest)
Guest
Posts: n/a
I have all the signs of MAF issue. check engine light with applicable codes. But just yesterday, it started roughly and then would only idle. Nothing would happen when I pressed the gas pedal. No acceleration or engine rev at all. I turned off and on the car a bunch of times before it finally worked. Could this be part of the same issue. If not. Any other ideas!? It's a 2000 boxster s.
Thanks. Brian
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-14-2013, 05:24 PM
Nick at Pelican Parts's Avatar
The ECU compares the Throttle position and the mass-air flow. Any thing that throws off that relationship can cause the problem, dirty MAF, vacuum leak, dirty throttle plates, etc.
- Nick
