LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
I replaced the 2 radiators in my boxter 97, and still the heat is up over 200 degrees, i see no leaking but suspecting the fan. is there a way to adjust the pressure in the radiator or to adjust the water circulation cooling. i also begun to hear some disturbing noise when transmitting knowing my boxter is a tip-tronic model
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Maybe you have a bad water pump or the thermostat could be sticking closed. Does the system have air trapped in it?
- Nick |
