![]() Quote:
The mention of NASA brings up a good example - following Jake's logic we should have never gotten a man on the moon. Sure we tested rockets and had some experience - but LANDING on the moon!?!? It wasn't experience that got us there, it was science! Science that was drawn from other areas, other disciplines than landing on the moon. Personally then I am very interested in what science outside the tiny world of our M96 engine has to say about this problem because it's a big, big world Jake and we have been dealing with these kinds of problems long, long, long before you ever cracked open your first M96 engine. ![]() Kirk Bristol |
Just a casual observer, as I sold my last porsche 2 months ago, but I've always been a bit perplexed by the defensiveness shown by a certain company. $10k fixes should be expected in such an expensive car.. etc etc. That may be the attitude of a certain % of Porsche owners, but there are far more DIYers who are here for both advice, but also because we buy parts from Pelican to install ourselves.
And I hope that every company that gets to represent their brand here, or in the other POrsche forums, do spend advertising or give other support to the people who make these sites happen. /rant
1982 911 SC 3.0L |
If I have any bit of advice that may be worth anything, it would be this: If you are selling something, stay off the forums. Trust me, no matter how many people trash your product on a forum, no body cares. You will not loose sales. Nothing will change. If you feel a response to defend your product is required on a forum, do it like this: "I know exactly what you want. Call me and I can explain how we can do this for you. Looking forward to hearing from you". Last word on this, you can't win an argument on a forum. There are too many people who have much more time than you, who have nothing better to do (or even worse, retired), and they will never quit. Last edited by White, Walter; 12-01-2013 at 11:00 AM.. |
Well Kirk, let's see if your unbiased or not. Let's see you post a fair and honest critique of DOF's marketing.
![]() From the research I have done, "Full" ceramic bearings (not to be confused with the "Hybrid" ceramic bearing) are not appropriate as an IMS bearing, but I bought one of these "inexpensive" full ceramic bearings (from the great land of China) mostly to study the cage, which is PTFE (Teflon). Anyway, what a wonderful device. I was absolutely amazed at how light it is, but the way it just keeps spinning and spinning when you give it a twirl. No lubrication, and so smooth you think it has an air cushion instead of balls. It is a 608, which is very small (about the size of a dime). But that made it even more amazing since it has so little mass, the way it keeps spinning and is so smooth. Last edited by White, Walter; 11-26-2013 at 08:07 AM.. |
We have chosen not to support DIY installs or supply products for these retrofits, that costs us money, but it maintains and perpetuates a positive reputation of the product and thats all that matters over the long haul. We didn't just arrive here and we have 30 more years to play this game. Quote:
This same info is given TO ALL distributors and is included in product descriptions, if the installers didn't tell the owners of the car this, thats not our fault! Anyway, we are all talking in the past tense anyway, because its all changed (again) and you didn't even know it.
Jake Raby Flat 6 Innovations and Aircooled Technology IMS Solution Inventor US Patents:8,992,089/ 9,416,697/ 9,687,974/ 9,909,369 '64 356C Outlaw,'76 912E,95’ 993,89’ 964 &'88 Carrera Last edited by NOTASIX; 11-26-2013 at 01:16 PM.. |
The IMS (intermediate shaft) problem is fascinating. These discussions have been going on for years because of the major consequences of its failure. OEM ball bearings have steel balls, steel races (the inner and outer collars), a steel cage to maintain proper spacing between ball bearings, and dual plastic seals on both sides of the bearing with grease packing.
Ball bearings can fail because of the following (taken in part from Ball Bearing Lubrication in Centrifugal Pumps | Maintenance World – An article source for maintenance management and equipment reliability professionals A. Contamination of the bearing oil or grease by water moisture or foreign particles. As little as 0.002% water in the bearing oil will reduce bearing life 48%. B. High heat caused by too much lubrication. With to much lubrication the bearing will consume energy as it plows through the lubricant. This energy will show up as heat added to the lubricant causing it to first lose its viscosity and then the lubricant will begin to form varnish and coke (i.e. solids) as it gets hotter. The recommended oil level should be half way through the bottom ball when the pump is at rest. The problem with grease and oil lubricants is their low specific heat and their poor conductivity. It is for this reason that it is not recommend to put any type of oil between dual seals if it can be avoided. C. Of course, too little lubrication will cause failure. D. If loads are too massive, the bearing will crushed, bent, etc. immediately. My limited observation of the failure of ball bearings is that the steel cage is a critical component of catastrophic ball bearing failure. As the friction becomes too large either because of poor lubrication, too much lubrication, or contamination by foreign objects, the steel cage stops rotating properly with the steel balls. Once the cage starts to lose its integrity friction increases even more leading to total disintegration of the cage. This results in the two steel races and ball bearings remain pretty much intact (although damaged), however the cage disintegrates into pieces. Because the balls are no longer properly spaced within the inner and outer races, the two races separate leading to catastrophic failure of the bearing. In IMS failures the debris is carried throughout the engine causing even more damage. Regarding the IMS bearings in Porsches, it appears that the following are generally agreed upon. 1. The early double row ball bearing (up to about MY2000) in the M96 engine has a very low, but real, failure rate (maybe <1%). 2. The first small single row ball bearing (MY2001-2005) in the M96 engine has the highest failure rate (about 8%), and is the smallest of the three ball bearings. 3. The second larger single row ball bearing (MY2006-2008) in the M97 engine has a low failure rate to date (about 1%). 4. The bearing load capacity of the double row and second larger single row bearing is about twice that of the first small single row bearing (see bristol, Direct oil injection 5. The oil level in the IMS bearing with the engine off and the car level is about 25% up from the bottom of the bearing, and is nearly ideal (see feelyx, Direct oil injection). Once the engine is running, the oil level must fall, probably below the IMS bearing altogether. 6. Track driven cars appear to have fewer failures than “garage queen” cars that are driven more gently. Track driven cars are also likely to have modified sumps allowing for storage of more engine oil. 7. Removal of the outer seal of the IMS bearing probably improves bearing life (see LN Engineering or Flat 6 Innovation websites). It is unclear if removal of both seals would be beneficial. 8. IMS ceramic bearings use ceramic balls with steel inner and outer rings. While the ceramic material itself is stronger than steel, it is also stiffer, which results in increased stresses on the rings, and hence decreased load capacity. However, they can be more effective in environments where lubrication is less than ideal (see Ball bearing - Wikipedia, the free encyclopedia). 9. The seals were never expected to keep the original grease in the bearing and the oil out. Seals can keep the dirt out and the grease in when the operating environment is air, but the seals could never be expected to keep engine oil out when the bottom 25% of the bearing is submerged in oil. Consequently, it is inconceivable to believe that Porsche engineers would expect the IMS bearing to be lubricated by grease. The following is one way to integrate these findings (none of these are new thoughts but they are all in one place). Obviously, the ball bearing application in the IMS of Porsche engines is flawed, with the double bearing and second larger bearing being able to withstand more deterioration before failure compared to the first small bearing used in MY2001-2005. A completely submerged ball bearing would also fail from the increased resistance due to too much lubrication whether or not both seals were in place or removed. If the bottom part of the bearing was always in oil, then it would be properly lubricated probably regardless if both seals were present or not. However, the IMS bearing is only in oil before the engine is started. Once the engine is running the oil level in the sump decreases and no longer submerges any part of the bearing, and the presence of both seals will make any splash lubrication even more problematic. Consequently, removing the outer seal will allow for some improvement in lubrication. An engine that is raced or tracked will be constantly accelerating and decelerating, thereby splashing the sump oil upward toward the IMS bearing compared to a “garage queen” car that is driven gently. The recommendation by LN Engineering to replace the small single ceramic bearing every 50,000 miles suggests that splash lubrication is too marginal even for a ceramic bearing to be dependable. This suggests that all types of IMS ball bearings require improved lubrication. The Tuners Motorsport (Pedro’s TechnoFix) Direct Oil Feed (DOF) has the possibility of properly lubricating the IMS bearing under the following conditions: (1) There is not too much oil fed to the bearing. It appears that the port in the IMS flange was altered last year to supply less oil (about 400cc/min from 1,400cc/min -see forums). Hopefully, 400cc/min will not be found to be too much lubrication. (2) That the oil is clear of debris particles that could otherwise become trapped in the bearing. It is possible that the bearing could act somewhat as a filter, and with the high flow of oil from the DOF the bearing may have an increased probability of being damaged by debris. In comparison, because the volume of oil due to splash lubrication would be smaller, there may be a smaller probability of debris damaging the bearing. Consequently, using only well filtered oil is probably critical. (3) Because the DOF appears to apply the oil at right angles to the bearing, hopefully the axial force of the oil hitting the bearing gage will not cause it to deform or wear improperly. A spray of oil may be better than a stream of oil. The IMS Solution (Home) also uses DOF but to a new IMS bearing that is not a ball bearing. So the obvious question is: Why did the Porsche engineers design the IMS bearing used in the water cooled engines until 2009. Apparently, they could no longer use plain bearings that were pressure fed at both ends of the IMS in the newer water cooled engines, in contrast to the old aircooled engines. Consequently, Porsche decided upon a ball bearing at one end, and initially it seemed to work in engines with the double row ball bearing. Because there were too few IMS failures with this engine, Porsche did not recognize the ball bearing actually was a critical weak point. However, by the second design with the small single row IMS bearing, the problem became readily apparent. Consequently, they had enough time to alter the engine design to incorporate a larger single bearing in the M97 engine, but they needed more time to design and deploy the next generation of engines that did not use an IMS (in 2009). And Porsche was not going to stop selling cars just because of an intermittent, catastrophic engine problem. Why then, did the engineers continue to have the IMS bearing installed with both seals? The most likely answer is that they thought the bearing received enough lubrication particularly since the bearing was submerged 25% in oil with the engine off. And by keeping the seals in place, any oil in the bearing may be kept inside the bearing. In addition, they probably thought that the presence of both seals was important in keeping debris out of the bearing. However, we now know that the presence of both seals keeps lubrication out while the engine is running, and this becomes a more important factor than keeping debris out. Lastly, the corporate side of Porsche decided it would cost less to the company to deal with engine failures on an individual basis, and perhaps also on a class-action basis then to order a recall to solve the IMS problem in all of their engines. |
If a little is good, then more is always better? That mindset is like the "bigger is better" mindset. If that was the case we'd all be driving around with 10 liter engines with a full inch of valve lift and ports large enough to drop a tennis ball through. Not the case. Thats a pretty good first post!
Jake Raby Flat 6 Innovations and Aircooled Technology IMS Solution Inventor US Patents:8,992,089/ 9,416,697/ 9,687,974/ 9,909,369 '64 356C Outlaw,'76 912E,95’ 993,89’ 964 &'88 Carrera Last edited by NOTASIX; 01-15-2014 at 05:03 PM.. |
That would assume the car is level. |
Don't fool yourselves.. The 9a1 engines were still impacted by the accountants and removing the IMS and subsequent components reduced engine costs.
With a 2014 9a1 apart right now, and a 2013 going back together tonight, we've learned a few things about the 9a1 over the past 4 years of internal exploration with those engines. Just see page 66 of last month's Panorama for a taste :-)
Jake Raby Flat 6 Innovations and Aircooled Technology IMS Solution Inventor US Patents:8,992,089/ 9,416,697/ 9,687,974/ 9,909,369 '64 356C Outlaw,'76 912E,95’ 993,89’ 964 &'88 Carrera |
Regards, Maurice. |
1. The earlier 2 row bearing is longer and as it is pressed into its bore, I think it is more self-aligning, because of its length. Even if the back of the bore is not square, it will more-or-less be square in the bore. It also uses the W or crown type separators (cage, but with this type I think separator is a better term for the W type). 2. The single row bearing is much narrower, and when it is pressed into its bore, I think misalignment could be a factor. If is is pressed against the rear of the bore, and that seating surface is not square to the axis of the shaft, misalignment can again be a factor. This bearing also uses the J type cage. 3. The larger later model bearing, being both larger in diameter and longer than the earlier single row, could be less susceptible to misalignment I think, and, because of its overall larger size, I think it is probably more tolerant to the torsional loads created by possible misalignment. It too uses the J type cage. This is why I think the ball bearing is used in the design. They can accept a degree of torsional loading, created either by misalignment on installation or by deflection of the shaft. |
Accrochez-vous bien de vos rêves..........." |
Hi All from the U.K.
After reading the Ims debate, on many Forums, for the last 6 months since buying a Boxster, I felt I would make a Post. I have come from 45 years of Lancia ownership, and after using my Son`s car, has been the only car that compared to a Lancia in road manners. I bought the car for peanuts" because thats all they sell for in the U.K. I was unaware of the IMS "Cockup" Removal of the Oil Filter, and tearing it apart, I saw the the shiny dust. The car has sat in the Garage never to be started, till a replacement Bearing is fitted. The "Solutions" appear to be:- The Ceramic Bearing, which I assume can only be fitted by Vestal Virgins judging by the price. The Plain oil fed bearing, which looks to small to last. Then there is the "Feelyx" design. This Guy must be the only one who has ever dismantled an electric motor, car alternator and the like, to reveal a bearing held in a housing, and the spindle goes round and round. I can only think of a Bicycle Wheel and a cheap cooling fan, where the middle is held, and the Outer moves. I understand his design has been sold off, Will it ever reach the market? Is it over Oiled for a ball race? I find all the above "man in a shed" fixes" takes some believing, with a car coming out of a Large factory like Porsche. There is a common mind set these days, which I call the "The Emperor`s new Clothes trick" ( from the Children`s fairy Tales) whereby only the very intelligent are able to see the fine weave of the cloth, and not that the Guy was naked. Porsche have made these "garments", and are laughing all the way to the bank, with your money. In the UK in the 70`s the joke doing the rounds was "What the difference between a Skip ( a skip is a roadside Rubbish container) and a Skoda, answer: the Skoda has 4 wheels. Skoda went broke bought up by VW. It needs a rubbish Porsche Campaign, On your track racer have Decals " Porsche designed by cretins" Etc. with enough bad press to make new buyers ask questions. And Maybe a Factory Mod for the IMS. Remember the Lancia Beta in the late 60`s, after recognizing the poor sheet metal used. They offered to "Buy Back" all the Beta`s instead of just injecting some Waxoil in the box sections. Would Porsche have done this? No, there advice would be go and buy our new model, you "Very Very Intelligent people" feel the new weave of the cloth(The Emperor's New Clothes - Wikipedia, the free encyclopedia) Apologies for any offence caused. John
This looks interesting:
Yeah.. I know the guy that developed it, he is a real *******.
He invented this tool, too... It apparently works like magic to install a dual row bearing into a single row shaft without disassembly :-)
I saw that picture on 986forum tool thread but underestimated the size of the tool, so I couldn't see how it would mount until I saw the video.
The Single Row Pro IMS Retrofit on Vimeo |
I am hoping for the best too. Hope something arrives soon. Last edited by White, Walter; 01-22-2014 at 01:19 PM.. |
