911 tweaks's Avatar
how do I check a/o clean the a/c drain in 99' boxster...??Li
a puddle happens in the passenger footwell when the a/c is run...my guess is that the condenser a/o evaporator or what ever a/c part is there is having problems with discharging condensate when it is working, thus the puddle that happens...
My initial thought is to open up what ever is there & investigate, but, I would rather have some insight from a fellow pelican on this subject before I dive in & I cannot find any articles addressing my experiences & dont want to wast time doing such if it wont fix the puddling occuring....
Any tips a/o how to clean a/c drain on car a/o what may be the issue...?? thx, bob
I live for 911 tweaks...
Old 07-04-2013, 02:06 PM
JFP in PA's Avatar
Drain runs under the car, near the centerline and just ahead of the firewall. You need to put the car up in the air and blow some low pressure air into it to free it up,
Accrochez-vous bien de vos rêves..........."
Old 07-04-2013, 02:36 PM
911 tweaks's Avatar
thx for your reply...however, if I do this, will I be blowing the blockage further back up into the system...??
Should u remove the assembly in the passenger footwell & start there cleaning & blowing in the direction of water flow...??
thx, bob
Old 07-04-2013, 06:05 PM
JFP in PA's Avatar
thx, bob
No, because to get at the heater box end you need to take the dash apart. Usually, there is just a bit of mold build up that once knocked loose, gets flushed out by condensate from the AC system.
Old 07-04-2013, 06:59 PM
JFP's advice is excellent.
If you want to look further, you could visually inspect the drain hose from where it exits the heater box under the dash to where it exits the car. To do this you will need to remove several things. First, remove the foam cover under the passenger side of the dash to reveal the bottom of the heater box. Then peal the carpeting back and follow the drain hose from the box to the hole in the floor. If you pull the hose out, be careful. You might end up with a lot of condensate on the carpet and floor.
In my car, I pulled the drain hose out of the floor exit hole. I haven't pulled it out of the heater box so I don't know how easy it is to put back in.
Old 07-04-2013, 08:02 PM
911 tweaks's Avatar
thx guys...I will report back what I find & what I do...stay tuned...bob
Old 07-05-2013, 06:38 AM
