Guest
Posts: n/a
Hi Wayne.I have just had my Boxster s 2000 Serviced i also had the coolant System Drained the Problem i have is the engine overheats when the engine is running it shows 90 when you turn the engine off it shows 120 i have also noticed that there is a lot of air when you remove the filler cap filler cap do i need to bleed the system .
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Yes. Porsche service procedure uses a vacuum fill but you need to have the tool and a compressed air source. This will take a decent amount of time to bleed
- Nick |
