Obd code 1324 on 99 boxstr
Hi
My 99 blew aos 1k miles ago at 125k Replaced along with serpentine and coil paks Couldnt get spark plug out of frnt pass plug, had to helicoil cyl nextoit Now slight engine miss,ck eng lite and 1324 code What do i look for? Rube |
Paul V
Looking thru service info, all I could find is that the timing chain is out of position for Bank 2, also "This fault can be stored only if the engine was disassembled and the
allocation of the outlet camshaft with respect to the inlet camshaft was incorrectly set." I hope gthat someone can chime in here with additional info for you. Regards, paul...
----------------------------------------------- 07 Boxster S, 03 MB E320 (wife's car), 10 Subie Forester X |
Obd code 1324 on 99 boxster
Thanx for reply
Nothing done to timing Wonder if isb caused prob Rube |
Sorry meant ims
Rube |
