-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   Question on Boxster Engine Sensors (http://forums.pelicanparts.com/boxster-cayman-forum/777042-question-boxster-engine-sensors.html)
CCorey (guest) 10-18-2013 04:26 AM
Getting fault code P1397 on 2000 996 C4. Can't figure out how to get to sensor with out dropping engine. Is thereanother way to get to it ?
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 10-18-2013 04:26 AM
Not sure what kind of vehicle you have, but here is some general info on the M96 engine:
There are two camshaft position sensors, depending on which side of the engine you are replacing it on the procedure varies. On the right side, remove the A/C compressor, then you can access the sensor.
For the left side sensor, you will have to remove the left side intake manifold runners. Once removed you can remove the sensor.
- Nick
