pavel (guest)
Guest
Posts: n/a
I've got fluid coming out from bottom hole in clutch assembly - mostlikely salve cylinder need to be replaced. I can barely see it on transmition. Also removed left rear wheel to get easier access but it did not help. How to get better access to replace cylinder?
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-07-2013, 04:39 AM
Nick at Pelican Parts's Avatar
To improve access, you can remove the transmission mount. Place a jack under the transmission, then remove the mount fasteners. Then lower the transmission an inch or two. Don't go too far and monitor the vehicle to be sure no hoses or wires are stretched.
- Nick
Do I understand correct - everybody replaces a slave cylinder almost blind?
Old 11-07-2013, 03:26 PM
