schumacher667 (guest)
Guest
Posts: n/a
Hello from Ireland, I have a 98 2.5 non egas,manual Boxster and also a complete 99 3.4 non egas manual motor.Any of the physical aspects of the motor change,I dont see as a problem, but when it comes to the DME,I was wondering if it would be possible to simply change the engine ECU,security ECU,keys,barrells etc.all out of the same 996 carinto the boxster?are the harness's compatable?I will be installing a 3.5" air duct.where i am i dont have access to a PST-2 or similar.so i would like the least amount of problems as possible.looking forward to your opinions
Regards Mick Wade
This post was auto-generated based upon a question asked on our tech article page here:
Old 02-22-2014, 07:10 PM
Nick at Pelican Parts's Avatar
The more you swap over from the donor car the better. I cant be sure about the harnesses, etc. It will be an experiment on your part to see what works. You can start by comparing part numbers to see what matches and what doesn't.
- Nick
