Lambda emissions failure
I have a 2003 2.7 boxster, which has just failed the NCT emissions test (roadworthiness test in Ireland)
The test here uses a device which samples and measures the exhaust fumes. The car failed on lambda out of range (high) with a reading of 1.10 (had it checked twice and confirmed). The technician who did the last check said that the lambda value was very unstable and would be in range momentarily/sporadically and then jump back and forth to a high out of range value. I've done an ODB check and it shows a pending code P0136 (one of the rear oxygen sensors)> my understanding is that the rear sensors have no control over the mixture and therefore this is unlikely to be the source of the problem.? In addition the car is making a screeching noise at start up and the car pulls a vacuum on the filler cap (but no white smoke) I believe this is likely to be a faultily AOS 1>Am I correct in the assumption that the code P0136 is unlikely to be related or the cause? 2> Can a faulty AOS cause a high lambda reading? 3> Any other potential causes for a high lambda reading Thanks in advance for any help on this. Stewart |
You certainly need to correct the bad AOS before you worry about anything else.
Tom Coradeschi 03 Boxster |
A hole in the AOS means the MAF isn't giving the computer a correct reading of the amount of air coming into the engine and thus you get a wrong air/fuel mixture.
Since you are dumping oil into the engine, you can foul the Lambda (O2) sensors. |
| Tags |
| aos , emissions , lambda , mot , nct |
