-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   TPMS sensors for $171 (http://forums.pelicanparts.com/boxster-cayman-forum/810512-tpms-sensors-171-a.html)
Dkennel 05-10-2014 07:40 AM
I have had some intermittent problems with the tire sensors over the last 6 months on my 2008 Boxster. Finally about 2-3 weeks ago I had the continuous warning light and all sensors were off.
My solution: I ordered a set of four sensors from oewheelsllc.com , including shipping I paid $141 for four sensors! My local tire shop charged me $25 for installation and with a $5 tip I ended up with a grand total of $171 for four new sensors installed.
No more error messages!
Miguel Antonett 05-20-2014 01:32 PM
I understand there are different identifycation codes for the sensor/transmitter/reciver combo. I was told there are six different ones. How did you identify yours, in such way they are compatible with the receivers on the car?
Dkennel 05-20-2014 04:31 PM
I ordered the sensors based upon my make, model and year. There are different frequencies for boxsters, some use 315MHz others 433, as far as I know you just need to get the right one for your make and year. If in doubt you could pull just one sensor and verify the specs on it. I had no trouble just ordering the generic Titan sensors for my model year. If you have concerns you can also buy the OEM beru sensors, a set of four will cost less than $400, a fourth of what some Porsche dealers charge. I think there are some artificial mysteries created that are supposed to force you see the dealer. I went through that with our daughters SLK, Mercedes wanted to charge close to $400 to replace one sensor. I did the same thing on her car and paid $5 to get a generic tpms sensor installed and have not had a problem for over a year now.
Dkennel 05-20-2014 04:34 PM
You can call Titan tpms at 1-888-249-2688, they should be able to help find the right sensors for your application.
Dkennel 05-20-2014 04:42 PM
Or call oewheels at 18662733651. They have the best prices, a set of beru sensors is $312, the Titans I bought were $136 + $5 shipping
Miguel Antonett 05-22-2014 01:07 PM
Many thanks! I'll give it a shot.
Super 90 05-29-2014 01:16 PM
This is great information. Looking at the Titan site for my year Boxster, you can buy either the 315Mhz or 433Mhz sensors.
Anybody know if a Durametric can tell you the frequency you need without pulling one out? Or can the dealer tell you?
Thanks a lot.
Miguel Antonett 05-29-2014 01:52 PM
^^^I called OEWHEELS and they recommended to call the P dealer with the VIN to get the Mhz info...
Do you still have the 356?
Super 90 05-30-2014 07:05 AM
Heh... I wish I did! It was a gorgeous red coupe and when I think of what I sold it for back in the late 1970s, I almost cry.
Thanks for the info.
Super 90 05-31-2014 10:34 PM
FYI, I checked with the dealer and he didn't need the VIN... according to the parts guy, EVERY U.S. delivered 2008 Boxster uses the 433 MHz TPMS transmitters. I didn't check other years, however.
Miguel Antonett 06-03-2014 07:52 AM
^^^My Cayman S is 07 so...
BTW, this is the reason why I asked about your 356.
http://forums.pelicanparts.com/uploa...1401807079.jpg
Super 90 06-05-2014 12:58 PM
Wow... memories... mine was a near duplicate of yours. :) I had the earlier hubcaps, but that's nearly the only difference. Even the same color.
Makes me sad to think of what it would be worth now!
