Question M97.21 Engine Rebuild
Hi guys,
I am sending out my IMS to LN for upgrading and since the engine is already dissembled, I will be doing a few minor upgrades to the internals. I have the service manual but I don't see any info. on main/rod bearing clearances. I went into PET and it seems that there's only one standard size for both main and rod bearings. However, when I inspected the old bearings taken out of my engine, there were different sets of 5 digit numbers stamped on them. My questions are, what's the tolerable bearing clearances for this engine, and are there different sized bearings from the factory?
Old 06-13-2012, 11:10 AM
Originally Posted by TimeAttack View Post
Hi guys,
Porsche only supplies standard bearings & they don't supply the info you seek to authorized Porshe dealers.
Old 06-13-2012, 01:31 PM
Even authorized dealers don't know the bearing clearances? Wow
Old 06-13-2012, 10:13 PM
I don't think dealers were authorized to see or touch the bearings until a year or two ago.
Old 06-14-2012, 07:30 AM
Internal engine parts were not available nor were classes for the dealer techs as it was standard practice just to swap an engine ... I presume given the price of 911s it was assumed that this would satisfy. No one ever though of 12 year old cars or $8k price points for the cars.
And yes, it was about 2-3 years ago this policy supposedly changed. But I know dealers today without a single tech capable of entering the engine internals.
Old 06-14-2012, 06:24 PM
Very interesting info! I guess the only option for me is to purchase the bearings in standard size and hope that they work!
Old 06-14-2012, 09:36 PM
Not sure where you heard this. To answer your question every dealer with access to PIWIS WSM should have access to these numbers. Unfortunately due to the architecture of the IDS-engines it's just not common practice to machine the crankshafts or crank-cages, if I'm not mistaken Clevite does make over/undersize engine bearings and a little simple math will dictate the size needed. LN should have access to any info needed to get clearances within factory spec.
'01 986S - "Clubsport" Style Track car
'13 WRX Sedan - Daily driver
Old 06-15-2012, 02:14 PM
Where did I hear it...a Porsche press release. I'm sure I posted about it at the time though exactly when that was is lost in the mists.
Old 06-16-2012, 07:55 AM
We are talking about M97 engines. What is a IDS engine?
Old 06-16-2012, 09:51 AM
IDS = Integrated dry-sump. Also P10W is the dealer class for rebuilding the water-cooled sports car engines. I took it 3 years ago.
Old 06-17-2012, 03:10 PM
N it's just not common practice to machine the crankshafts or crank-cages.
I guess this is why the main bearings are only sold in standard sizes?
Old 06-19-2012, 09:20 AM
So Porsche refers to this engine family as IDS instead of M96/97? I thought the IDS was just a marketing term. Interesting this P10W class seems to have started around the time Jake Raby was revealing info on IDS engine internals.
Old 06-19-2012, 09:43 AM
The class was around long before 3 years ago, I just happened to take it 3 years ago. The IDS thing is indeed pretty much just a marketing term, I usually only use it when making comparisons between the GT/Turbo engines and the regular Carrera engines. And yes that's why the bearings are only sold in standard sizes, I'm sure some aftermarket company makes bearings for it, only thing is you'd have to retreat the crank after machining it.
Old 06-19-2012, 11:07 AM
Sil40sK, thanks for sharing such useful info!
Old 06-19-2012, 11:15 AM
Just an update. I purchased the standard main and rod bearings based on my VIN and after fitting them, their clearances are as follows :
Mains +.0023-.0025"
Rods +.0018-.0020"
Do they look ok to you guys?
Old 11-16-2012, 07:11 PM
TimeAttack,
I'm VERY interested in your progress, as i may be close behind you in trying to recondition my 2001 2.7 with a rod knock...
Any pointers????
Thanks!
Jonathan
81 Light Blue 928 with tan interior, 4.5L Auto
83 Champagne 944
2001 Boxster, base 2.7
Old 11-16-2012, 07:46 PM
Originally Posted by kuehjo View Post
TimeAttack,
Any pointers????
Thanks!
Jonathan
I'm no expert but will be glad to share any info. should I have them.
Old 11-16-2012, 08:06 PM
TimeAttack,
Any pointers????
Thanks!
Jonathan
If you have a rod knock you must have spun rod bearings. The rods are not rebuildable but I have good used rods available.
Old 11-19-2012, 10:19 AM
PM sent!
83 Champagne 944
Old 11-19-2012, 11:55 AM
hi curious as to how you took your measurement of clearance? 0.002 sounds like a reasonable value but i dont have specific numbers to offer
Old 11-19-2012, 02:35 PM
