			got a 2000 Boxster S and runs rough at idle, getting codes for misfire for 4, 5, 6, and I noticed the exhaust collector is oil soaked, ( just that bank)pulled spark plugs and they are wet. checked the AOS by disconnecting it with no luck.also checked for vac leaks, none found.
				what would cause oil leak in the whole bank to be misfiring? thank you.
	Accrochez-vous bien de vos rêves..........."  |
			Thanks for the info.
	if thats the case how can I get all that oil of the system, also by just going to the oil cap it doesn't seem hard to get out. Another question, why would it fill just one bank?. thanks again.  |
 If you look at how the AOS connects to the intake, the oil would naturally favor one bank over the other.
			 one of gods prototypes
			You can pull the plenum and the throttle body as one piece,  then reach into the intake with clean tags to get about 90% of the oil out. .... Don't leave any rags in the intake lol
			Pulled the throttle body and its full of oil, wii remove the AOS and get one coming.
					let you know how it turn out when I install the new AOS. thanks for the info.  |
