nyctinman (guest)
Guest
Posts: n/a
I have a 1997 Boxster. The driver side window is not going down to clear the window gasket when the door handle is pulled. The window is not loose and the switch works to make the window go up and down. Is this a micro switch issue?
This post was auto-generated based upon a question asked on our tech article page here:
Old 05-29-2014, 07:16 AM
Nick at Pelican Parts's Avatar
Does it not go down with the inside or outside handle? If just one, it could be the switch for that handle.
- Nick
It will not go down with either handle. I can hear the switch click but the window does not move. Console switches work fine. I also read that there could be slack in the window cable but I cannot move the window when grabbing the top of it. Passenger side works fine.
Old 06-10-2014, 05:59 PM
