Schnell Gelb
Coolant re-fill kit - cheaper.Does it work well?
Coolant refill problem solver:
IIRC ,when refilling it is easy to get big air-lock problems.
The smart tool to use is a Vacuum filling kit - UView Airlift 550.000 is the Vacuum tool often mentioned but it is expensive for a seldom used tool - $130+.
Amazon.com: UView 550000 Airlift Cooling System Leak Checker and Airlock Purge Tool Kit: Automotive
I found a half price generic version and wonder if anyone has tried it? It is approx. $72 on Fleabay and other sources.
Amazon.com: FJC 43610 Radiator Coolant Vacuum Refill Kit: Automotive
There are many vendors of this tool # 43610 so it may be re-branded.
I have tried a Lisle funnel on my modified Miata with mediocre results:
Amazon.com: Lisle 24680 Spill-Free Funnel: Automotive
This may help on the Boxster if you raise the rear of the car very high?
2001 Boxster S
Engineers muse
Old 07-17-2014, 09:35 AM
turboflyer's Avatar
Works fine have done the porsche, and motorcycle. Not sure of the higher quality but my ebay item I have had for years.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return." ~ Leonardo da Vinci
2007 Ducati 999S Team USA , 2005 BMW BCR R1100S
2001 Boxster S w/tip
Old 07-17-2014, 09:10 PM
