Canada Lad (guest)
Guest
Posts: n/a
I've decided to finally deal with the worn 2nd gear syncromesh on my '03 Boxster S. My current thinking is to drop the existing transmission, break it down, replace parts as necessary, and reinstall the unit.
As it will take some time to break down and rebuild the transmission, I'd like to get some advise on the best and safest way to move the disabled vehicle out of the shop bay while the rebuild is being completed.
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-20-2014, 12:06 PM
Nick at Pelican Parts's Avatar
I would remove the engine and trans together, then separate them. With them out, you can secure the axles up and install the subframe support, then roll the vehicle outside. Be sure to chock all four wheels.
- Nick
