Starter or Engine Problem
My '99 Boxster suddenly started with a problem. When I turn the key to start the engine I can only hear a click when the starter motor engages. Eventually the engine would turn and start. At first I thought the starter motor was bad and ordered a new one.
After replacing the starter motor it keeps doing the same clicking noise and the engine won't start. Any ideas what can cause this behavior? |
Thanks for the tip. I have measured my battery and I have 12.4V, on the positive screw of the starter I have 12.4V, on the S screw when I turn the ignition switch I have 9.4V and I have a positive drop of 11.4V. Can it be the ignition switch electrical part the problem?
I have done all the tests to the battery, even tried a new battery. It seem that the switch might be the problem. When you first connect the battery and turn the key nothing happens, after a few tries you get a click on the starter but no cranking.
Please help. I have replaced the ignition switch and nothing. The battery is fine as I have double check it. The problem must be a short, but not sure where. I recall having the first symptoms when replacing the alternator. After several tries the engine would crank. Now I just get a click.
Thanks a lot JFP, I have found the problem. I did the voltage drop test and found the weak point. For everyone else having the same problem, check the connection box that couples the battery with the starter and alternator. Mine was really dirty and a little bit loose.
Thanks to all! Happy Porschering!!! |
| All times are GMT -8. The time now is 09:08 PM. |
