A couple of steps back please - how do you remove/replace the BULB in the Hazard Warning Light SWITCH. Does it simply pull-out or does the switch need to be disassembleud?
Thanks __________________ This post was auto-generated based upon a question asked on our tech article page here: |
If I remember correctly, there is a small socket you remove, once the switch has been removed. Then pull the bulb out.
- Nick |
| All times are GMT -8. The time now is 02:37 PM. |
