Send a message via Yahoo to mjkcs
Thumbs down Top won't go down
'99 Boxster. The idiot light on the dash says that the top is not all the way up but it now won't go up or down. The fuse in the kick panel appears to be good. Is there any other fuses hidden somewhere in this car? I have a 328i convertible that has one in the trunk. I had a dead battery issue at the time this showed up. Could it be some sort of "reset" that needs to occur?
Thanks in advance.
2001 BMW X5 4.4, 2004 330ci, 2004 Porsche Cayenne S, 2001 330ci,
Gone but not forgotten: 1972 Prosche 914 2.0, 1997 BMW 328i Convertible, 1999 Boxster, 1999 BMW 540I, 2000 BMW 323it, 2000 BMW 323ci
Old 04-24-2007, 08:00 PM
AFJuvat's Avatar
It is usually the top latch switch that goes bad and prevents the top from moving at all.
You can try removing and installing the cabrio control unit - it looks like a double relay on the relay board.
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann.
Ihr Brunnen der nutzlosen Porsche Information
Old 04-25-2007, 06:16 AM
I will check that. Thanks.
Old 04-25-2007, 12:10 PM
I pulled the control unit and reinstalled it just like you suggested and the top works great...again. Thank you very much.
Old 04-29-2007, 08:41 AM
Hello,
I think I have the same issue. My top is currently stuck up, with the dash light on. If I unlatch the top, the windows will come down a bit, and when I hit the button to lower the top, I can hear the motor trying. When I hit the button it goes . My windows had the same issue so I replaced the regulators and that worked. Any idea about my top?
Also, where is the controller unit you guys are talking about? Any pictures would help!
Thanks!
Stu
Old 01-24-2015, 07:25 PM
