schumacher667 (guest)
Guest
Posts: n/a
Hi from Ireland again,i did the 2.5l to 3.4l conversion last march,all went perfect,started first time no cels etc. I have 14k klms on it since with no problems except I only used a standard sachs clutch with the 5 speed transmition and it has begun to slip while changing at full revs,what clutch kit would you recommend to use ? is the boxster s gearbox compatable ?I have the flywheel and clutch assembly from the 996, will the splines match ?because I would like a six speed box and can get one for the same price as a high performance clutch for the 5 speed box.lookin forward to your thoughts,regards mick
This post was auto-generated based upon a question asked on our tech article page here:
Old 12-27-2014, 06:47 AM
Nick at Pelican Parts's Avatar
Any performance clutch should upgrade you from the factory stuff. Did you resurface the flywheel when you installed the engine? I would have it inspected before the next clutch job, if it is worn, it could be the cause of the worn clutch.
- Nick
