Sherif (guest)
Guest
Posts: n/a
I have a Carrera 996.1 3.4L and my transmission that I have just installed is working properly, but the gear indicator on the dashboard is flickering between P and 4 what is that signal and how can I fix it
This post was auto-generated based upon a question asked on our tech article page here:
Old 01-16-2015, 05:46 AM
Nick at Pelican Parts's Avatar
The range switch may not be connected correctly. Check if the connector is seated properly.
Also check the DME for fault codes. If the system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
- Nick
