PR (guest)
Guest
Posts: n/a
After changing the engine oil and filter, my 2003 986 is a little sluggish. The oil level is good, Mobil 1 0-40, and a Mann-Filter HU 719/5 X. The only thing I did different from the instructions was that I snapped the filter to the plastic housing and then attached the housing to the car. Could this be the reason? I highly doubt it, but just looking for answers.
This post was auto-generated based upon a question asked on our tech article page here:
Old 03-20-2015, 04:32 AM
Nick at Pelican Parts's Avatar
I don't see how the oil change could cause a sluggish engine, unless it was overfull and blowing by into the intake.
I would look elsewhere. Check fuel control and see what is lacking when the problem is present.
- Nick
If you are worried about how the filter is seated, just remove it and reinstall it per the instructions. You'll only lose about a quart of oil if you are quick.
Old 03-20-2015, 10:18 AM
