Krish (guest)
Guest
Posts: n/a
I have a 2005 987 boxster.
When I open the roof, the windows go down as normal and the rood will go back.
When I only open it half way to clean then go to put it back down it will not go back down. I will have to put it all the way back down and then up again.
When I put it up again the windows do not drop in time.
Any advise on this?
This post was auto-generated based upon a question asked on our tech article page here:
Old 03-19-2015, 05:56 AM
Nick at Pelican Parts's Avatar
I have not seen this particular issue before. I wonder if this is normal function. If the top stalls, then it has to be closed. Best bet would be to check for faults when the issue happens.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
