-   Boxster & Cayman Forum (http://forums.pelicanparts.com/boxster-cayman-forum/)
-   -   I hate to ask "Torque value for Trans Guide Tube Screws? (http://forums.pelicanparts.com/boxster-cayman-forum/858457-i-hate-ask-torque-value-trans-guide-tube-screws.html)
2k-986-s 03-30-2015 09:44 PM
Is there a torque value for the two screws that hold the transmission throw out bearing guide tube, or is it " put some blue loctite and torque down good and tight?"
I can't find one anywhere and maybe I answered my own question, can't find it because one doesn't exist :)
roadster49 09-26-2016 09:13 AM
Same question. And how did you remove the ones already installed
JFP in PA 09-26-2016 09:42 AM
You should be using new M8X22 MM bolts (they are single use only), and the torque is 24 Nm or 18 ft. lbs.
