I hate to ask "Torque value for Trans Guide Tube Screws?
Is there a torque value for the two screws that hold the transmission throw out bearing guide tube, or is it " put some blue loctite and torque down good and tight?"
I can't find one anywhere and maybe I answered my own question, can't find it because one doesn't exist
Same question. And how did you remove the ones already installed
You should be using new M8X22 MM bolts (they are single use only), and the torque is 24 Nm or 18 ft. lbs.
Accrochez-vous bien de vos rêves..........." |
