PeterB (guest)
Guest
Posts: n/a
I have a 2000 Porsche Boxster. Front cross drilled Zimmermans on the way from you guys. Talking to friends on the track, I'm being cautioned about the Caliper bolts being seized when I loosen them and to be gentle to avoid breaking the bolt which is a real problem to fix if that happens. So when I put the bolts back on, what is the proper torque so I don't over tighten them?
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-20-2015, 12:01 PM
Nick at Pelican Parts's Avatar
Caliper to wheel carrier 85 Nm, the bolts have to be replaced each time they are removed.
- Nick
