Andy (guest)
Guest
Posts: n/a
The clutch pedal seems to stick just after the biting point the clutch engages and works just fine there is no slipping or noise. It has a distint change in pressure as you lift it up, the last part seems to stick then Pop up as the car warms or on a longer trips it seems to get better?
This post was auto-generated based upon a question asked on our tech article page here:
Old 04-23-2015, 08:56 AM
Nick at Pelican Parts's Avatar
Sounds like the master cylinder is starting to go. If it lacks the strength to return the pedal, you will have just what you described.
- Nick
JEC JEC is offline
I had a similar symptom and it turned out to be a bad pressure plate.
It got to the point that if I went over 4,000 rpm before shifting the pedal wouldn't come off of the floor.
I replaced the clutch disk, pressure plate, throwout bearing and flywheel.
Old 04-25-2015, 06:52 PM
