What is this coolant system part?
This is located over the transmission under the trunk area on passenger side. It is what burst when it overheated.
If this is a Tiptronic transmission car (it is always a good idea to include the car year, model and how it is equipped in a post), that is the control valve for the transmission oil cooler.
Accrochez-vous bien de vos rêves..........." |
My bad 2001 Boxster S with automatic tranny. Thank you.
PCA Certified D.I.
It looks like a water cut off to the heater core.
1986, '87,'88 928S4, 2006 Cayman S Cabluey, 2006 Cayman S "Burn Notice" |
The heaters in these cars are a constant flow design, there is no water cut off valve. Temperature is controlled by moving air mixing doors in the heater box.
