Apparently at least inner CV joints are identical to those on Z3M. The kit for Z3M contains Hylomar to seal flanges. Do we need use it here too?
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-02-2015, 05:03 AM
Nick at Pelican Parts's Avatar
As a BMW Z3? I am not familiar with the compatibility.
Give our parts specialists a call at 1-888-280-7799. They can help you figure it out.
I opened a post in our forums. A Pelican community member may be able to answer your question.
- Nick
Schnell Gelb
I've recently done this job. I imagine that if the BMW mating faces were poorly machined ,that an RTV sealer may prevent oil that separated from the grease from seeping out.
It would do no harm to use a generic RTV sealant there IMHO.
I would be much more concerned about the bolts that attach the CV joint. They have an unhappy tendency to loosen! Some blue Loctite in cleaned threads(brake cleaner) ,new bolts and a torque wrench will fix that.
2001 Boxster S
Engineers muse
Old 06-09-2015, 06:07 PM
