Intermediate shaft
I recently bought a 97 Boxter with a broken engine - allegedly a broken timing belt. Rather than repair it I found a used motor (2.5L) and installed it. Before doing so I checked compression and replaced the IMS bearing. All good. It lasted 1 day, the timing went, the exhaust valves bounced off the pistons and bent open resulting in no compression etc. When I stripped it down I found that the sprockets on the IMS had moved on the shaft resulting in the cams going out of time. I later stripped the original motor and found the same problem with that shaft as well.
I have taken the shafts to my friendly machinist and he is going to pin all sprockets to the shaft for me.
I have not noticed that this is a common problem with this motor through my searches on the net and was wondering if others had experienced something similar.
Old 06-15-2015, 08:39 PM
JFP in PA's Avatar
Yes, it does happen. This is one reason you should never push on these sprockets while doing an IMS retrofit.
Accrochez-vous bien de vos rêves..........."
Old 06-16-2015, 03:44 AM
