paul (guest)
Guest
Posts: n/a
I did the test of removing the tube between the throttle body and AOS, blocking off both ends, when I started the car oil poured outfrom somewhere around the AOS! I am guessing this is not supposed to happen?
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-28-2015, 06:11 AM
Nick at Pelican Parts's Avatar
Was it out of the AOS? I would try to pinpoint the source of the oil leak. Check if is the AOS, a line of an engine seal.
- Nick
